Truck is a 51 3100. A PO swapped the rear end at some point and it now has an open drive shaft. I have looked all over the rear end for numbers to id it and can't find anything. It has a 10 bolt cover is a 6 lug. The only noticeable feature I have seen are 3 fins or ridges on the driver side of the housing facing the front of the truck. Below are the links to some pictures that I took. Any help would be greatly appreciated.
'55-'62. There should be a number stamped on the passenger side of the 3rd memeber. That will be the code for year/ratio. Here's a picture showing where the number should be. If you can get the code, I can decipher it for you.
