1 members (JW51), 186 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#684589 10/09/2010 8:16 PM
Hi everyone,
Truck is a 51 3100. A PO swapped the rear end at some point and it now has an open drive shaft. I have looked all over the rear end for numbers to id it and can't find anything. It has a 10 bolt cover is a 6 lug. The only noticeable feature I have seen are 3 fins or ridges on the driver side of the housing facing the front of the truck. Below are the links to some pictures that I took. Any help would be greatly appreciated.
Chris
[IMG]http://i682.photobucket.com/albums/vv183/kenneycj/1951%20Chevy%203100/101_0026.jpg[/IMG]
[IMG]http://i682.photobucket.com/albums/vv183/kenneycj/1951%20Chevy%203100/101_0025.jpg[/IMG]
[IMG]http://i682.photobucket.com/albums/vv183/kenneycj/1951%20Chevy%203100/101_0036.jpg[/IMG]
3B Offline
Hy kenneycj, it looks like a 55B - 59 Chev 1/2 ton rear axle to me, hope that helps.
'55-'62. There should be a number stamped on the passenger side of the 3rd memeber. That will be the code for year/ratio. Here's a picture showing where the number should be. If you can get the code, I can decipher it for you.
Bill Burmeister
Bill,
Thanks for the picture. That helps alot. I will try to take a look tomorrow and see if I can find the code.
Chris
Ok I found the code--looks like NK 10 20. Any help in decoding it or a link to somewhere I can decode it.
Thanks!
Chris
I'm coming up with a '55 1rst series with a 3.90 gear. The K part of the code doesn't seem to be listed, but all of the N codes come up as '55 1rst.
Bill Burmeister
Thanks Bill!!!!!
Dear Bill: I posted somo sort of the same problem that Chris: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=684707#Post684707
I also have the picture of the transmission: Transmission cover Can you help out.
