8 members (Southerntruck, Gray_Ghost, Bill Hanlon, Otto Skorzeny, JW51, MRMEROTH11, Mike Burns, KEVINSKI), 77 guests, and 1 robot.
Topics128,133
Posts1,056,396
Members48,441
#683829 10/07/2010 1:27 AM
Hello All!
I am replacing the rear coil springs on my 62 C10. Here is my question...many vendors (LMC and others) will list stock rear springs for 63 - 66. Others will list stock rear springs for 60 - 66. Will 63 - 66 springs fit a 62?
A little advice will help. Thanks!
I ordered my rear springs from Classic Parts of America for my 63 C10. This is the description from the website.
1960-72 Coil Springs Rear
pn 74-481.
These are the stock height and they fit right in to my 63. I would assume yours is no different. Hope this was helpful, good luck.
I bought the rear coils for my '65 from CPP, their list also says 63-72?
http://www.classicperform.com/6092chevtrk.htm#21
Perhaps they list them this way becasue GMC's had torsion bars until '63? ohwell
Best call them just to be sure. And don't buy springs from LMC, they buy them from CPP and mark them up $70 nono... see this thread for more details... https://www.stovebolt.com/ubbthread...;Words=emptor&Search=true#Post495875
My rear springs were heaver than the stock springs on the C-10. I understand that some C-20's had coils in the back too they were bigger in diamiter than on the the stock spring C-10's. By that I mean the coil thickness these are 7/8" where the stock is 3/4".
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #684456 10/09/2010 5:11 AM
All of the '60-'66 Chevy light-duty trucks (C10 & C20), had trailing arms/coil springs rear suspension assemblies. The GMC trucks of the same years, had leaves, as standard equipment, in the rear. The 1/2 ton front & rear coils are lighter than the 3/4 ton front & rear coils. The torsion bar front suspension systems in '60-'62, did not have coils on the front. Perhaps the vendors acknowledge this when providing the description for the rears? I believe the 1/2 ton rear coils are interchangeable from '60-'66.
Don G. #684527 10/09/2010 2:56 PM
62Blue
Don
The springs I received from CPP were 5/8" in diameter.
Lighter than original, indeed. I believe NAPA still carries the front and rear replacement coils for the '60-'66 Chevy light-duty trucks.
