8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Does anyone have any tricks for keeping the stuff inside caulking tubes from drying out after you open them? No, this isn't about household caulk, I bought a tube of seam sealer and the thing dried up very quickly despite my capping the tube with a tight fitting cap from a Magic Marker which usually works with household caulk. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I use electrical tape than pinch the end and fold over and give it one more wrap.
Pete | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes Woody, use it all up! DG
Denny G Sandwich, IL
| | | | | Joined: Jul 2009 Posts: 11 New Guy | | New Guy Joined: Jul 2009 Posts: 11 | I use a lot of Fusor seam sealer, the best trick I found is to squeeze some out and leave a inch or two"tag" hanging from the tip, it will harden up and when you pull it off it will take the hard stuff out of the tip with it, leaving you clear..but it doesnt always work with all brands! | | | | | Joined: Oct 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 56 | I think I read it in Family Handyman. Dip the caulking tube, whatever it is into the a can of plasticoat (the stuff you dip pliers into to make rubber handles). It works GREAT!
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Great suggestion Dave. It's actually PLASTI DIP You win the prize THANK YOU
