Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (Robert Crandall, Wheelie, ShopRag, cmayna, baldeagle, Lugnutz, Otto Skorzeny, Hawkman), 49 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#684270 10/08/2010 4:00 PM
A couple weeks ago, my distributor crapped out and the gearpin sheared off. I purchased a rebuilt distributor and have been trying to time the motor ever since without much success. She runs but it just isn't quite right. It surges under load and you can hear a couple slight backfires while driving. We located what we think is the timing mark on the flywheel, it appears to be and arrow, instead of a steel ball. Any suggestions would be appreciated!
Pieman #684288 10/08/2010 6:10 PM
The steel ball should be there.Make sure you clean the flywheel beyond the "arrow" to see it. I think your timing is a little off.
Drew
DrewP #684321 10/08/2010 8:05 PM
The steel ball is really tiny, like a BB. It comes 5 deg before the triangle which is UDC or Upper dead Center.
1951 1 Ton Completed
truckernix #684615 10/09/2010 11:44 PM
Where exactly are you viewing the flywheel to see a timing mark?
bowtiefan #684727 10/10/2010 9:13 AM
bowtiefan
#1
#2
It is located on the right side of your block just above where the starter is attached...
Pic #1 shows the steel ball before it is on the needle, Pic # 2 shows the steel ball lined up with the needle...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
