8 members (Wally / Montana, Steelonsteel, Tronman, 1955 1 Series, Bill Hanlon, Hotrod Lincoln, LAROKE, 1 invisible),
137
Mod | | | Forums66 Topics128,201 Posts1,057,279 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68422 11/10/2006 7:05 PM | Joined: Nov 2006 Posts: 7 New Guy | | New Guy Joined: Nov 2006 Posts: 7 | I bought an overhaul gasket set from PAW. The rear main seal was not like the old one I took out. I called their tech line and they told me that the gasket set I got doesn't come with a rear seal for my engine. I wish I knew why. They gave me a phone number for the gasket company and they explained that the gasket I got was not for my engine. I've tried around town with no luck. The one listed at the chevy dealership is no longer available. My original had little "tails" on the bottom half, that fit into slots of the bearing cap. Any information on this subject would be appreciated. | | |
#68424 02/05/2007 4:52 PM | Joined: Feb 2007 Posts: 3 Junior Member | | Junior Member Joined: Feb 2007 Posts: 3 | I had the same problem, so i just went to napa and they ordered me one. now im trying to find the torque spec for the main bearing caps, any idea what those are, or where i could find them? | | |
#68425 02/06/2007 12:45 AM | Joined: Dec 2006 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 65 | The torque spec for the mains is 65 ftlbs and the rods are 40 ftlbs. Hope this helps.
Sean
doing what you love is happiness loving what you do is freedom
#68426 02/06/2007 1:47 AM | Joined: Nov 2006 Posts: 7 New Guy | | New Guy Joined: Nov 2006 Posts: 7 | The main bearing torque is indeed 65 ft. lbs. However, the rear bearing should be done last. It should be torqued to 10 ft. lbs. and then, tap the end of the crankshaft on the front or toward the rear. Now tap it in the other direction. This is suppose to insure that the upper and lower bearing thrust surfaces are lined up. Finally finish torquing it. | | |
