Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Woodcmiami, rfs56trk, Cosmo, cmayna), 37 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#68410 11/10/2006 12:11 PM
Just swapped rear for one out of a 75 Lemans. Tried to buy wheels and tires from a guy at work. The wheels look like they're off a mini van or something (Chevy center caps) but the bolt pattern of the new wheels is smaller. I thought all Chevys were the same. Any idea why they wouldn't fit?
Jason
Your lack of preparation is not my emergency
#68411 11/10/2006 5:02 PM
i believe chevy had a small and large 5 lug bolt pattern
#68412 11/10/2006 5:33 PM
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#68413 11/10/2006 11:07 PM
A 5 lug x 4-3/4" pattern has a measurement of 2-3/4" between the center of the 1st hole and the 3rd hole. A 5 lug x 4-1/2" pattern has a measurement of 2-5/8" from center of the first hole and the third hole. There is only 1/8" difference between the hole centers so I'd suggest you make a template as using a tape measure can be a bit iffy!!!!
I took some poster board and cut out a little template that I used to quickly check stud and hole patterns. Check pg 11 of my webshots for a pic. Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#68415 11/11/2006 3:50 AM
Are the wheels from a front drive minivan (LuminaAPV/Venture)? If so, they have a metric 115 mm bolt circle. Those won't work with the rear drive pattern. There is also a small pattern front drive that is 100 mm I beleive. Rear drive Chevrolet would either be 4 3/4" or 5" with 5 lug, with the larger being used mainly on police/taxi/SS Impala/Caprice full size '71-'98 truck, and the Astro van. May also have been used on the later C5/C6 'Vettes.
Bill Burmeister
