1 members (baldeagle),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68410 11/10/2006 12:11 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Just swapped rear for one out of a 75 Lemans. Tried to buy wheels and tires from a guy at work. The wheels look like they're off a mini van or something (Chevy center caps) but the bolt pattern of the new wheels is smaller. I thought all Chevys were the same. Any idea why they wouldn't fit? Thanks,
Jason
Your lack of preparation is not my emergency
#68411 11/10/2006 5:02 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | i believe chevy had a small and large 5 lug bolt pattern | | |
#68412 11/10/2006 5:33 PM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 |
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#68413 11/10/2006 11:07 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | A 5 lug x 4-3/4" pattern has a measurement of 2-3/4" between the center of the 1st hole and the 3rd hole. A 5 lug x 4-1/2" pattern has a measurement of 2-5/8" from center of the first hole and the third hole. There is only 1/8" difference between the hole centers so I'd suggest you make a template as using a tape measure can be a bit iffy!!!!
I took some poster board and cut out a little template that I used to quickly check stud and hole patterns. Check pg 11 of my webshots for a pic. Hope this helps. | | |
#68415 11/11/2006 3:50 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Are the wheels from a front drive minivan (LuminaAPV/Venture)? If so, they have a metric 115 mm bolt circle. Those won't work with the rear drive pattern. There is also a small pattern front drive that is 100 mm I beleive. Rear drive Chevrolet would either be 4 3/4" or 5" with 5 lug, with the larger being used mainly on police/taxi/SS Impala/Caprice full size '71-'98 truck, and the Astro van. May also have been used on the later C5/C6 'Vettes.
Bill Burmeister | | |
