| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | I need an exhaust manifold for my 1965 230 inline six that has the heat riser with working valve. I tried RockAuto and they don't carry them anymore and LMC doesn't have the heat riser on them. Mine has a broken bolt hole and the heat riser is frozen so hard I can't get it to work.
I'm rebuilding it pretty much original but I'm not a fanatic when it comes to original parts as long as they look original.
Thanks Guys!
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | Just soak that heat rizer for a week or two, it will come loose. Try a little heat around the shaft after soaking for a while.
Both of my manifolds have one ear broke off the ends. They seem to seal just fine with out it.
Joe | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Joe,
Any idea what to soak it in? I used a couple cans of oven cleaner on it already. Maybe some gas in a rubbermaid type tub?
Tom
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 |
| | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | Any type of spray oil should work. Just go to the local store and look for something that soaks in rust, there are plenty of brands out there. Just keep it wet for a while and every so often, tap a little on it to see if will move a little. Don't forget to spray both ends, the dead end has a small cap in the manifold so spray from the inside of the manifold on that end and both sides of the weighted end.
Joe | | |
