2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#683820 10/07/2010 1:17 AM
Trying to get the 216 running in my '48. Should I be able to get the starter to turn over by touching the housing to ground on a battery and a hot wire from the post on the starter to the positive post, completely bypassing the trucks wiring? I cannot tell if my starter is good or not. I have 2 and neither will turn over using this method.
You have to push the button if the switch is on it.
Cletis #683921 10/07/2010 5:16 AM
You might want to take the starters to a good starter and generator shop for testing ? Knowing they work saves a lot of time .Just my two cents. Good luck and be careful .
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
If the starter is not mounted, it will jump out of your hands with the reaction torque. That is just a hint to help you avoid bashed fingers.
1951 1 Ton Completed
+1 on that advice! Clamp the housing in a vise, firmly, but not tight enough to distort it, before applying any power!
