| | | Forums66 Topics128,012 Posts1,055,313 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Trying to get the 216 running in my '48. Should I be able to get the starter to turn over by touching the housing to ground on a battery and a hot wire from the post on the starter to the positive post, completely bypassing the trucks wiring? I cannot tell if my starter is good or not. I have 2 and neither will turn over using this method. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You have to push the button if the switch is on it. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | You might want to take the starters to a good starter and generator shop for testing ? Knowing they work saves a lot of time .Just my two cents. Good luck and be careful . | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If the starter is not mounted, it will jump out of your hands with the reaction torque. That is just a hint to help you avoid bashed fingers. | | | | | Joined: Feb 2004 Posts: 29,743 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,743 | +1 on that advice! Clamp the housing in a vise, firmly, but not tight enough to distort it, before applying any power! Jerry
