| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68343 11/08/2006 12:19 PM | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | The wheel base on an Art Deco(1/2 ton) is listed as 115 inch wheel base. Thats wheel to wheel. If you dont mind me asking-What is the width of the rear axle and the front axle? I need the measurement from one end of the break drum to the other end, and shouldnt the front length be the same as the back? Please help me out..thanks | | |
#68344 11/09/2006 5:48 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy packhorse32, I can only find tread width spec.s at the moment, front is 56 3/8" rear is 59 1/4", hope that helps. | | |
#68345 11/09/2006 10:42 AM | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | It does 3B thanks tons... | | |
#68346 11/11/2006 12:07 PM | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | After a bit of research and much help from other stovebolters I was able to find that the Dodge Dakota comes out ahead as being the closest in matching wheel base and track width. Check it out: 1946 Chevy ½ ton truck= 115 inch wheel base, rear track width 59and 1/4inch or 60 and 3/8 inch, Front track width 57 and 21/32 inch or 56 and 9/16 inch.
1997 Dodge Dakota truck reg. cab=112 inch wheel base, Rear track width is 61.5 inches or 62.5 inches, and front track width is 60.8 or 61.5 inches.
1982-2004 Chevy s-10 wheel base is 118 inches for the fleetside standard cab longbed, but the track width is 47. 5- 49 inches. | | |
#68347 11/12/2006 2:21 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You really need to check those track width figures for an S-10...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#68348 11/12/2006 6:02 AM | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | Yeah your right oldsub-the front is reading different. I am getting diffrent numbers on the HAMB and one here too. | | |
