4 members (MickeyP, TexasA&M48Truck, walter74, cmayna), 42 guests, and 4 robots.
Topics128,012
Posts1,055,321
Members48,419
#68343 11/08/2006 12:19 PM
The wheel base on an Art Deco(1/2 ton) is listed as 115 inch wheel base. Thats wheel to wheel. If you dont mind me asking-What is the width of the rear axle and the front axle? I need the measurement from one end of the break drum to the other end, and shouldnt the front length be the same as the back? Please help me out..thanks
#68344 11/09/2006 5:48 AM
3B Offline
Hy packhorse32, I can only find tread width spec.s at the moment, front is 56 3/8" rear is 59 1/4", hope that helps.
#68345 11/09/2006 10:42 AM
It does 3B thanks tons...
#68346 11/11/2006 12:07 PM
After a bit of research and much help from other stovebolters I was able to find that the Dodge Dakota comes out ahead as being the closest in matching wheel base and track width.
Check it out:
1946 Chevy ½ ton truck= 115 inch wheel base, rear track width 59and 1/4inch or 60 and 3/8 inch, Front track width 57 and 21/32 inch or 56 and 9/16 inch.
1997 Dodge Dakota truck reg. cab=112 inch wheel base, Rear track width is 61.5 inches or 62.5 inches, and front track width is 60.8 or 61.5 inches.
1982-2004 Chevy s-10 wheel base is 118 inches for the fleetside standard cab longbed, but the track width is 47. 5- 49 inches.
#68347 11/12/2006 2:21 AM
You really need to check those track width figures for an S-10...
#68348 11/12/2006 6:02 AM
Yeah your right oldsub-the front is reading different. I am getting diffrent numbers on the HAMB and one here too.
