| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | while my friend jack and i were putting the head back on george henry this weekend, we had a discussion about how the head may not have all the good old lead build up that it developed over the years now that it has been cleaned up.
prior to the cam gear failure, we had done a valve check and were very pleased with the discovery that in spite of the engine (to my knowledge) has never had the valve clearance checked before, was completely within factory tolerances. in other words, there was no significant valve recession even though i have been running un-leaded fuel in it since i have been driving it daily since 95.
so...would now be the time to think about adding something to a tank of fuel every now and then or do i just run the one i brung?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I wouldn't worry about it.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Run the one you brung. The way it got you there (no lead additives).
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | TEL, as used to increase octane, is a sacrificial deposit and is continuously precipitated on the seats and worn off by the closing valve - there is no continuous build-up. I'm not sure which gasoline grades (other than premium) used TEL, but until it was banned it's been used since WW2 (that's what the pump sign "ETHYL" means)- so many stovebolts got it daily. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That be just after WWI for TEL Panic. And it was a cheap way of tempering the "octane rating" as compaired to blending like they do today to tame Octane. Also it was a REAL big money maker for the "ETHYL" corporation stock holders. I posted a bunch about this in another thread recently but don't remember where it was.
You won't have any valve problems with modern fuels p.j. and there is really no need for those fuel additives, ever! They're like those weight loss diets, a total scam. Denny Graham Sandwich, IL
Denny G Sandwich, IL
