5 members (66flea, cmayna, Wally / Montana, walter74, Forty9), 110 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
#672248 08/22/2010 10:12 PM
1 Offline
So on my first trip in the rain, i find that my wipers "stick" in the up position. They go up, get to their topmost point, then won't go back down until you get out and push them down. I figure it's just a little bit of rust or tightness in the wiper mechanism (beneath the cowling, don't know the right name for it). So I removed the cowling and sprayed some WD40 on all the joints and hinges. So now, second time out in the raid the drivers side blade seems reluctant to move back and forth and the passenger side is flailing about wildly. A couple miles down the road, the arm on the passenger side comes free from the stub protruding from the cowling and the driver side breaks the plastic connector between the arm and the blade. So, fun drive. Anyway, the arms are pretty beat up looking and both blades are broken now (i may or may not have run over the passenger side blade when it fell off) I was wondering if anyone has had any experience with the blades and arms from LMC, and also what recommendation you have for freeing up the under-cowling mechanism?
Can't speak for the LMC parts but if you need the transmission arms or a good single speed motor (or both) I have a spare set from my rebuild.
The glass is twice as big as it needs to be.
1 Offline
I'm going to try to find some better lubricant that will last longer and see if the mechanism will start to work a little smoother.
1 Offline
Budman, if you still have an extra set of transmission arms in good shape I'd like to see about getting it from you. I tried to replace the wiper arms on my truck and I've found that the left attachment knob has been distorted so that it cannot hold the wiper arm firmly. I guess I have one of the previous owners to thank for that!
On the 61 I used to have, the wiper mechanism worked but was horribly noisy. I used "Liquid Wrench" on it instead of WD40...silenced them right up, and I drove it for a year and a bit, and it sat out in the rain, snow sometimes. Never squeaked again.
Several years ago mine were noisy and sticky too. I used 30 weight and they've worked like a charm and are as silent as can be expected.
My other truck is a Ducati
Be sure to check the "clocking" of the transmission arms. If they are clocked incorrectly, they will damage the transmission arms, wiper arms or blades. The manual shows the correct method, to do so.
Apprentice
Apprentice
The modern chrome plated wiper arms sold by most vendors are really just crap. I purchased a set that rusted & fell off several times even when not in use. I gave up & bought a set from NAPA. I bought a set of TRICO 51's(http://www.tricoproducts.com/brochure.cfm?brochure=225&location_id=10 )
These are made of unpolished solid stainless, no cheap chrome plating, they are adjustable for length & can be selected for right & left side use. You add your own wiper blades and can even buff them to a shine if you want.
Have not had a problem since.
Blue 666
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
Apprentice
Apprentice
Sorry, should have rechecked the link prior to posting.
This shows the Trico Part # & application. The closest you get is a 1970 c40,50 or 60 but it fits.
http://www.tricoproducts.com/replacement/onlinecatalogs/online_catalog.aspx?opt=2
Blue 666
Blue666,
Thanks for the link, very helpful. thumbs_up
So you are using:
Trico Arm P/N 51-250,
Trico Silver Blade P/N 33-150,
Trico Refill P/N 46-150
Correct?
Apprentice
Apprentice
Hot Rod John,
Glad to be of service. I am using the Trico Arm P/N 51-250 but I don't recall the wiper blade part numbers.
I have really been pleased with the Trico's. They are built for use rather than looks but they should buff up nicely if so inclined.
Blue 666
what about the arm that mounts to the shaft coming out of the cowl on a 66 chev/gmc....who sells those or are we stuck with LMC ?
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
