8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible), 148 guests, and 5 robots.
Topics128,089
Posts1,056,137
Members48,435
#683194 10/04/2010 10:20 PM
I removed the fuel tank from my 37 chevy 1/2ton truck for cleaning and now I need some advice. If I clean it...how would I go about that? If I replace it...where can I find one that would work under the seat like the original or how would I go about relocating the tank to another spot on the truck?
Thanks!
Charlie
Ex Hall Monitor
Ex Hall Monitor
If by cleaning you mean old fuel and general crud google fuel tank cleaning. There are a number of products on the market. Another option if there is a radiator shop that will do it is to take it to a radiator shop & have them put it in their chemical tank. No shop around here will do that. If by cleaning you mean a lot of rust there are kits for derusting and coating the inside of the tank. I use Kreem on a motorcycle tank years ago with success. I restored the tank in my 38 using muriatic acid to remove the rust, brazed the larger holes then coated the inside with Redkote. Four years so far with no issues.
I have a 37 pick-up also and am looking for tips on removing the gas tank from under the seat. Any tips?
V
VEW Offline
V Offline
I've cleaned tanks myself before (on my 41), did a through job, used the "white" sealer and was happy with it. But I much prefer taking it to a raditor shop and having them boil it out and use the "red" sealer. Did my 50 Willys for $135. I will have them do my 49 Bus in a couple of weeks.
~ Victor
1957 3100 - moved on
1 Offline
I'm replacing the tank in my '32 Chevy sedan and will send the existing tank out for a rehab with a vendor in southern Calif. When I get it back it will go up on Ebay. Tanks for a '32 are hard to find.
Normbc9
If your existing tank is in decent shape, you can get it cleaned / repaired as per above suggestions. If you want to relocate it under the bed, you can purchase steel or poly tanks that locate to the rear of the axle for around $ 200. Some guys have also used tanks from assorted junk yard vehicles. Fillers can be located in the bed, or routed out the sides. Have a look at Chevs of the '40's, or Summit Racing Equipment for ideas.
1940 Chevy KC 1/2-Ton
