| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | I took my truck out for its first drive yesterday and ran into a problem. Whenever I get above 1500 RPM the engine starts popping, alot. I checked the valves, set the timing, and made sure the carb was set right. On a hunch, I took off the vacuum advance and plugged the line, and the engine ran much better. I could drive the truck and it had no problems revving right up past 3k, with absolutely no popping. I can't figure it out, any ideas?
The engine is a '58 235 with hydraulic lifters. | | | | | Joined: Oct 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 56 | Sounds like the timing and or dwell is off.
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Vacuum leak from a bad vacuum advance?
58' 3200 235 3-speed/OD
| | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Vacuum leak from a bad vacuum advance? I tried waving an unlit propane torch and didn't get any change. Plus, the vacuum advance is new from classic parts. I'll definitely give it a good looking over, I never thought of that. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Do you have the vacuum advance line connected to the fitting at the venturi area on the carburetor, or to full manifold vacuum? You've got over-advanced timing for some reason, either an incorrect setting of the ball & pointer, or too much vacuum on the advance unit. Try turning the dizzy housing clockwise with the advance connected a little at a time during a test drive until the pop goes away. Jerry
