6 members (MRMEROTH11, FAST55, 1955 1 Series, Hotrod Lincoln, greenie-reddy, Otto Skorzeny), 127 guests, and 1 robot.
Topics128,051
Posts1,055,768
#682959 10/04/2010 1:26 AM
I took my truck out for its first drive yesterday and ran into a problem. Whenever I get above 1500 RPM the engine starts popping, alot. I checked the valves, set the timing, and made sure the carb was set right. On a hunch, I took off the vacuum advance and plugged the line, and the engine ran much better. I could drive the truck and it had no problems revving right up past 3k, with absolutely no popping. I can't figure it out, any ideas?
The engine is a '58 235 with hydraulic lifters.
Sounds like the timing and or dwell is off.
Vacuum leak from a bad vacuum advance?
58' 3200 235 3-speed/OD
I tried waving an unlit propane torch and didn't get any change. Plus, the vacuum advance is new from classic parts. I'll definitely give it a good looking over, I never thought of that.
H Online: Content
Do you have the vacuum advance line connected to the fitting at the venturi area on the carburetor, or to full manifold vacuum? You've got over-advanced timing for some reason, either an incorrect setting of the ball & pointer, or too much vacuum on the advance unit. Try turning the dizzy housing clockwise with the advance connected a little at a time during a test drive until the pop goes away.
