12 members (TUTS 59, TexasJim50, Jay R, TooMany2count, amtrakjoe, Hotrod Lincoln, cmayna, Woogeroo, Rusty Heaps, Otto Skorzeny, 2 invisible),
93
Mod | | | Forums66 Topics128,134 Posts1,056,411 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 56 | After much work and research, I have completed a custom draglink and tie rod assembly. This uses modern heavy duty tie rods. It is also fully adjustable. I wanted extra wheel clearance and the convenience of a modern part. Doesn't it look like the stock 1 ton? It's not. It's for a 3/4 ton. http://s859.photobucket.com/albums/ab158/Duntov85/1952Chev3608 | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The pictures look good. Can you list the part numbers you used and any modifications you made?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 56 | They are custom tie rod ends. The sleeves are custom made as well. After many prototypes these are hollow to keep the weight down.
The tubing is 1.250" diameter. The threads on the tie rod ends are about 29/32".
I wanted something that was beefed up from stock so the wimpy OEM tie rod end wouldn't bow. I wanted a modern tie rod end, not that goofy old skool ball and cup setup, because I plan on using this truck for a daily driver. I want to be able to jack the truck up when I'm doing an oil change, shoot some grease in the kingpins, steering, and everywhere else and be done with it. This also gives me more clearance for the aftermarket wheels (replacements for FORD 1969 F-250 - they have 1/2" studs 8 bolt on 6.5) - Great replacements by the way and easy to obtain.
I also wanted something that looked very clean and stock. An ealier prototype had large jam nuts, but there was a problem obtaining tooling that would properly cut the threads. Using the clamp syle gives a little more realistic leeway.
Nothing was available for the 3/4 ton. This could also be used for a 1 ton and maybe a 1 1/2 ton, but I'd need to know what the length from center of the grease fitting to center of the other grease fitting on the tie rod assembly as it is assembled on the vehicle with toe set at 0 (zero).. From there I could compute the length of the custom sleeve.
If someone is interested in doing something like this, I will assist in helping you achieve this. I'd like to see more vehicles like these driveable.
