0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#682276 10/01/2010 6:26 AM
Apprentice
Apprentice
I have never painted so as I am putting my 216 engine back together I am using Rust-o-leum engine primer and engine enamel. Am I going to regret this later. It didn't seem like a bad idea when I started but after spending so much time getting 60 years of grime and rust off of engine parts I hate to think it has all been for nothing. What should I be using?
VHT paint is high temperature paint for the engine compartment.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
0
0 Offline
As long have you have cleaned and degreased the parts that you plan to paint well, I don't think you'll be disappointed with any brand of "engine" paint. You don't actually need primer anyway to duplicate the factory look. The factory did not waste the money on primer. Joe
If the paint you use recommends primer you should use the suggested primer.
I used Duplicolor engine paint (and primer) from NAPA on my engine, turned out very nice.
Most of the work was in the prep, stripping all the old paint and scrubbing every last inch with a brush and lacquer thinner.
Here's a picture of the stripped block
http://rides.webshots.com/photo/2387721890080251109siGDXz
Here are a few in progress and completed.
http://rides.webshots.com/photo/2987531930080251109rscvBI
http://rides.webshots.com/photo/2139348100080251109hatrCb
http://rides.webshots.com/photo/2205440580080251109TNUrGL
In the past I tried just steam cleaning and scrubbing the old paint really good, and painting over it. That worked well for a while, but eventually the old paint started to come off in places, with the new too. From now on I'll completely strip an engine before painting.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
I used por15s engine paint kit, comes with everything you need including industrial degreaser that work better than my farm implement degreaser. Ive used por15 for some quad frames before and the stuff is still going strong and looking great. Grigg is right tho, I would completely strip it down with thinner so you would have the best adhesion. Pic of my painted engine back in the frame. Painted Engine..
I never let the truth get in the way of a good yarn..
Apprentice
Apprentice
Thanks for the advice. Most of the parts I'm working on are so rusted that I'm taking them down to bare metal and the engine block I took to the machine shop where they vatted and tested it. I asked them not to paint it since they usually use a blue so they left it bare. The good thing I do like about the primer is that since most of these parts are pretty rusted there is a lot of pitting and the primer does a good job of smoothing out the small stuff
Could someone powder coat a valve cover without problems down the line?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Of course. It would look great and hold up very well.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Only issue may be matching paint to powdercoat if you intended for them to be the same color.
Grigg
---All pictures---
