5 members (Wheelie, Gdads51, klhansen, greenie-reddy, 1 invisible), 87 guests, and 3 robots.
Topics128,036
Posts1,055,452
Members48,422
#681851 09/30/2010 2:29 AM
Apprentice
Apprentice
We've decided to use stock frame. I'm thinking of 12 bolt chevy or 9 inch ford rear end. How do I get disc brakes on the front of a 47 1.5 ton?
Since you are downgrading the load capacity at the rear you might replace the front axle with a 1/2-ton type and then use one of the 5-lug or 6-lug conversion kits available.
If you want to maintain your load capacity you'll want to use a bigger rear than the 12-bolt or 9-inch and the 1/2-ton front would be the wrong answer.
All depends on the intended use.
If you'd prefer to keep your truck a real truck you may find some ideas here.
http://www.stovebolt.com/techtips/bigbolts/p30swap/
If you don't mind turning the truck into more of a car Steve's ideas could work just the same as they do for the 1/2 tons. You'll just have a heavier frame and larger than necessary fenders...
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
I did my own disk brake conversion on my 36 1.5ton axle using police tahoe brake parts. I fabbed up my own bracketry. I cant really speak to how well it works since my truck hasn't hit the road yet, but the calipers are massive twin piston set ups, so I do believe it will work very well
Originally Posted by TooMany2count
Pictures?????????
If so you should do a post on how you did it....joe
I'll second that,
Grigg
---All pictures---
I did a thread on it a while back, Ill have to do a little searching and see if I can dig it up
here it is.. https://www.stovebolt.com/ubbthread...;Main=90793&Number=633064#Post633064
I did do some more work on the set up, maybe I can find some updated pictures, The parts arent currently on the axle so I cant just go snap new pics.. I will look later.. back to work
What year Tahoe was it? Or does it matter much?
The rotors are used on lots of other vehicles.. escaled, suburban, pick ups..
I did have to machine the bore open on the rotor, no big deal for any shop with a lathe..
