| | | Forums66 Topics128,051 Posts1,055,734 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 35 Apprentice | | Apprentice Joined: Dec 2005 Posts: 35 | We've decided to use stock frame. I'm thinking of 12 bolt chevy or 9 inch ford rear end. How do I get disc brakes on the front of a 47 1.5 ton? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Since you are downgrading the load capacity at the rear you might replace the front axle with a 1/2-ton type and then use one of the 5-lug or 6-lug conversion kits available.
If you want to maintain your load capacity you'll want to use a bigger rear than the 12-bolt or 9-inch and the 1/2-ton front would be the wrong answer.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | All depends on the intended use. If you'd prefer to keep your truck a real truck you may find some ideas here. http://www.stovebolt.com/techtips/bigbolts/p30swap/If you don't mind turning the truck into more of a car Steve's ideas could work just the same as they do for the 1/2 tons. You'll just have a heavier frame and larger than necessary fenders... Grigg | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | I did my own disk brake conversion on my 36 1.5ton axle using police tahoe brake parts. I fabbed up my own bracketry. I cant really speak to how well it works since my truck hasn't hit the road yet, but the calipers are massive twin piston set ups, so I do believe it will work very well | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Pictures????????? If so you should do a post on how you did it....joe I'll second that, Grigg | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | I did a thread on it a while back, Ill have to do a little searching and see if I can dig it up | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | here it is.. https://www.stovebolt.com/ubbthread...;Main=90793&Number=633064#Post633064I did do some more work on the set up, maybe I can find some updated pictures, The parts arent currently on the axle so I cant just go snap new pics.. I will look later.. back to work
| | | | | Joined: Sep 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 99 | What year Tahoe was it? Or does it matter much? | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | The rotors are used on lots of other vehicles.. escaled, suburban, pick ups..
I did have to machine the bore open on the rotor, no big deal for any shop with a lathe.. | | |
