3 members (Hotrod Lincoln, Otto Skorzeny, Peggy M), 98 guests, and 3 robots.
Topics128,026
Posts1,055,409
Members48,422
#682260 10/01/2010 5:25 AM
I have a 58 step side and need some help with my front shock mounts. One upper bracket is broke off at about frame level. A new hole was drilled below and the shock attached. The other side appears to have broken off as well and welded to try to repair. One shock short and one long. Is there any source or alternative for upper mount replacement. I sure appreciate the help I've received from this site.
not uncommon to find'em that way, no replacement AFAIK except what's been done to yours or find a scrap frame you can cut the mounts off and bolt them on with grade 8
Thanks for the info. Interesting you say
not uncommon. Thought it was just me.
years of hard use on rough country roads with old broken or seized shocks and weak springs ohwell
One of mine on my '52 was broke. I bought a replacement from LMC. I used good Grade 8 bolts & nuts that fit the rivet holes (i.e. not from Lowe's). Mine were from a local nut & bolt store. I also used the red Loctite. This is #271 not the usual blue #242. According to the guy at the store the red is only removable with heat. I wouldn't want to take chances with suspension components.
Thanks. I was hoping I could find a replacement. Looked through LMC and others. Can find replacements for pre 55 mounts but nothing for late 50's. I think I'll get busy and hunt for an old frame for these mounts. I guess you could make something that would work but will keep my eyes open for the real thing.
I have the same problem with my 58. The DS upper shock mount is broken in two, and the PS upper shock mount hole has been widened out and the shock just rattles around.
I see the shock brackets for the 47-55 Trucks, and I'm wondering if I can use those and just use the older style shocks.
Has anyone tried this? Are the mounting holes the same?
Joe
1958 Chevy Pickup
1990 Ford F250
1997 Ford Ranger
2003 Harley Davidson
