7 members (2-Ton, MRMEROTH11, Gdads51, JW51, Shaffer's1950, Southerntruck, 1 invisible), 118 guests, and 1 robot.
Topics128,132
Posts1,056,378
Members48,441
Are there any after-market electronic speedometer-odometers available? If so, where and whats the prefered model?
Bill garvey
http://dolphingauges.com/dolphin_gauges.html
I have had good luck with this brand for electronic .My personal preference is mechanical.Most all vendors carry this brand also .
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Y
yar Offline
Y Offline
I have a Stewart Warner electronic speedo in my hot rod roadster. A positive feature is that it is adjustable for tire sizes and gear ratios. Two negative feature are 1. that the transition from one digit to the next is very jerky, not smooth like the electronic speedo on my Honda car and 2. it picks up an electronic signal from something else in the car for the first few minutes the engine is running when it has not been run for a while and registers speed and distance while the car is standing still.
Ray
Thanks a lot for the info , fella's. Bill
Bill garvey
Bill, here's what I've used. Modern Internals with nostalgic/retro looks.
New Vintage gauges
As yet I haven't driven the truck,so I don't know how they are,but if nothing else they look good!
More pix on Flickr.
New Vintage gauges
Did you do it???
And it so have you done a Tech Tip on how to do it????
I'd be one of many who like to see that.....joe
Guilty as charged! This link shows how I did it with brief descriptions below each picture.
Unfortunately you have to 'sacrifice' a set of original gauges,mine were toast anyway.
There's also a tech tip from another fellow 'bolter Danimal on the New Vintage site.
To be fair,that's where I got the idea in the first place....
Thanks again Dan!
More pix on Flickr.
I USED THE NEW VINTGAGES IN MY 53 3100, HAD TO GET TRIM RINGS FROM DOC'S KUSTOMS, BE CAREFUL WE HAD TO MACHINE THEM SO THE GAUGES ACTUALLY FIT IN THEM , FOR THE MONEY THE GAUGES ARE WELL WORTH IT,, INSTRUCTIONS ARE EASY ALTHOUGH I REWIRED MY TRUCK WITH A NEW HARNESS FROM REBEL WIRING(ANOTHER GREAT PRODUCT FOR THE MONEY)SO IT WAS PRETTY SIMPLE AND THEY ARE THERE IF YOU HAVE ANY QUESTIONS..
SCPOUSN, I didn't want to pay the $$ for the adapters(I'm cheap)
BTW You can turn your Caps lock off,there no need to SHOUT about it! wink
Joe, thats the very same one, Dan did his for the later gauges,so I just 'adapted' ('scuse the pun) the technique to suit the earlier pre 54 ones.
More pix on Flickr.
