| | | Forums66 Topics128,109 Posts1,056,260 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | has anyone ever removed a dash from a 55-59 cab ??? whats the process i have a gmc big back window cab and i need to take its dash out and install a 57 chevy tk dash is it just spot welded??? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes it's "just" spot welded, in about a zillion places, including the brace bracket under and behind the steering column - look it all over with the windshield out and it should be obvious .... the process has been discussed in the forums a couple times, requires a proper spot weld drill and care not to mess up the flange that mounts the windshield rubber
Bill | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I wound up having to use a cutoff wheel on the corners of the dash closest to the doors. Also, you'll be cutting spot welds on the sides under the dash. Just get a good metal cutting bit for those. | | |
