| | | Forums66 Topics128,162 Posts1,056,946 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | Does anyone know of a source for brake hoses for a 1954 Two-ton truck?
The local parts houses all stated that their books say that they are no longer available.
I've looked online but no luck there either. Maybe I'm just not looking in the right place?
I looked into having some made, but the hydraulic hose shop wouldn't do it because of "liability". I can't see much difference in liability between a brake hose and a hydraulic hose. If either goes, it could be a catastrophy.
Thanks for any help
| | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | I got my front shoes for my 46 COE 2ton from Obsolete chevy. They weren't in the book but they have alot of military surplus stuff. These brake shoes were galvinized and also riveted which I wanted. Ask for Mike,he knows more what they have than any one else. (1-800-248-8785 | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I got some from Carquest for a 2 ton GMC. Their computer only goes back to 1962, but they are still in the printed books and still in their warehouses. You just need to find someone who isn't totally reliant on a computer. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy MT53, my parts book says all three are the same Raybestos p/n BH4497, o.a.l. 16 7/8" 7/16" X 20 t.p.i. male thread on one end, 7/16" X 24 t.p.i. female thread on the other end, this end also has a retaining clip slot in it, hope that helps. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | The brake hose vs hyd hose liability thing is a common issue. What I came across more often was welding places that will make you a trailer, but wont make a roll cage because of liability issues. You would think a trailer coming apart on the road would be a bad thing, but evidently a failed roll cage is a bigger issue. It's all about that rediculous ripoff scam we call "insurance".
As far as those parts go, they dont make the hoses or front wheel cyclenders for my '56 either. But, the hoses from a later model are available & were only a few inches longer. 7/8" bore wheel cylenders were available from a '61, just had an angled fitting boss, but otherwise identical. Really, if you can find a local Napa shop with someone that knows how to use thier books, you'll be able to find something that works. May not be the same year, or exactly like original, but the parts are out there. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | NAPA has them. Just got one for my 53 6400. 17.00
| | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Try here: http://www.napaonline.com/Search/Re...k=Interchange%20Number&Nty=1&N=0That failing give Geoff a call at Alretta: 508-788-9409 his prefered method of contact. http://www.alretta.com/Geoff is a brake encyclopedia, he called out part numbers for the wheel cylinders on my '52 GMC 450 from memory. I caught him out of the shop when I first called, simply amazing!
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | I got them for a 6500 from Napa, take then old one in and do a picture book match | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | Napa does have them and if you have AAA card they will give you 10% off! | | | | | Joined: Apr 2007 Posts: 457 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 457 | I just got 2 ton brake hoses from NAPA last week. Ask for part# 36696. If they are out of stock, you can use part# 36540 (they are longer, but have the proper fittings).
Good luck, George | | |
