4 members (Otto Skorzeny, rfs56trk, Bill Hanlon, 1 invisible), 81 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
#681742 09/29/2010 9:11 PM
What is the best lubricant for the steering gear box on a ’53 Chevy 3600? My old shop manual says to use “Steering gear lubricant”. I don’t know what that is. When I remove the fill plug on top of the steering box, it seems that it is grease but it may just be 57 years of crud. I would think multi purpose gear oil SAE 80W-85W-90 that I use in the transmission and rear end would work but want to see what Y’all say before I make a mistake.
Any help is appreciated.
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
John Deere Corn Head grease. There is another one that I can't remember at the moment... Lubrite or something like that? Basically, self leveling grease is what you need. If you have very good seals, then the 90 wt. should work.
There has been a lot of discussion about this topic.
The original lubricant was a self-levelling grease. Penrite make an expensive equivalent; however, many people find that John Deere Corn Head Grease works quite well (and the price is right).
I found the Corn head grease at a nearby tractor dealer. It took a whole 14 oz tube! That baby hadn't been lubed in 57 years. I'll buy another tube just to keep it properly lubed. I purchased the little 3 oz palm grease gun from Harbor Freight for $3.95 and will dedicate it for this purpose.
Thanks for the input.
