| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | What is the best lubricant for the steering gear box on a ’53 Chevy 3600? My old shop manual says to use “Steering gear lubricant”. I don’t know what that is. When I remove the fill plug on top of the steering box, it seems that it is grease but it may just be 57 years of crud. I would think multi purpose gear oil SAE 80W-85W-90 that I use in the transmission and rear end would work but want to see what Y’all say before I make a mistake. Any help is appreciated. John
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | John Deere Corn Head grease. There is another one that I can't remember at the moment... Lubrite or something like that? Basically, self leveling grease is what you need. If you have very good seals, then the 90 wt. should work. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There has been a lot of discussion about this topic. The original lubricant was a self-levelling grease. Penrite make an expensive equivalent; however, many people find that John Deere Corn Head Grease works quite well (and the price is right). | | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I found the Corn head grease at a nearby tractor dealer. It took a whole 14 oz tube! That baby hadn't been lubed in 57 years. I'll buy another tube just to keep it properly lubed. I purchased the little 3 oz palm grease gun from Harbor Freight for $3.95 and will dedicate it for this purpose. Thanks for the input. John | | |
