| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | The previous owner of my 55 2'd series pickup installed a door lock in the driver's side door handle. I know it belongs in the other side. Am hoping that some kind soul can walk me through the steps necessary to remove the lock. Truck was recently painted inside and out so I want to be careful not to scratch or damage the fresh paint. Thanks!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | a driver side lock was optional so unless you are trying to win the most points in an originality contest, "belonging" isn't really worth the trouble ... but if you really need to fiddle, the easiest way would be to remove the inner door panels, remove the 2 screws that hold each outer handle in [if they're not corroded tight], switch sides and re-install
Bill | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Bill, My driver's side lock doesn't have a key so I bought a lock and key set and was planning to put the new lock in the passenger side door handle. Then I thought - why not put the blank button in the driver's side handle..... I thought the pushbutton was somehow attached to a piece of linkage. Apparently, it just pushes on something to open the door. Sounds easy to change.Screws shouldn't be rusty as it was only painted 18 months ago - without the door handles installed. Many thanks for your advice. Sam | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, easy - once you get the handle off you'll see the clip that holds the button in, don't let the spring jump away  Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I put locks on both sides of my 55 2nd. I had one key that opened either door and started the truck.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | .... I had one key that opened either door and started the truck. back in the day we called that a screwdriver  Bill | | |
