2 members (delky, Steelonsteel), 235 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
GPK 1961
GPK 1961
Truck is a fleetside long bed with a 283 V-8. Looking for what the original exhaust system would look like/where it should go.
Thanks Stovebolt
New project - 1961 Apache 10 Step-side
I think stock would be ram horns.
k10 Offline
The Assembly manual shows the setup for the V=8's. Rams horns are correct, then it goes 2 into 1 right after the the crossover pipe joins up. The crossover almost goes directly underneath the oil pan at the center of the engine.3743106 is the p/n for the crossover pipe. Then you have a pretty long can and then it exits on the driver's side. It doesn't show exactly how it ends. Section 408/ 20.00 is the section in the yellow and white 60-66 Chevy/GMC assembly manual.
GPK 1961
GPK 1961
Thanks K10
