0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | Are there any after-market electronic speedometer-odometers available? If so, where and whats the prefered model?
Bill garvey
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | http://dolphingauges.com/dolphin_gauges.htmlI have had good luck with this brand for electronic .My personal preference is mechanical.Most all vendors carry this brand also .
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | I have a Stewart Warner electronic speedo in my hot rod roadster. A positive feature is that it is adjustable for tire sizes and gear ratios. Two negative feature are 1. that the transition from one digit to the next is very jerky, not smooth like the electronic speedo on my Honda car and 2. it picks up an electronic signal from something else in the car for the first few minutes the engine is running when it has not been run for a while and registers speed and distance while the car is standing still.
Ray
| | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | Thanks a lot for the info , fella's. Bill
Bill garvey
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Bill, here's what I've used. Modern Internals with nostalgic/retro looks. New Vintage gauges As yet I haven't driven the truck,so I don't know how they are,but if nothing else they look good! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Bill, here's what I've used. Modern Internals with nostalgic/retro looks. New Vintage gaugesDid you do it??? And it so have you done a Tech Tip on how to do it???? I'd be one of many who like to see that.....joe Guilty as charged! This link shows how I did it with brief descriptions below each picture. Unfortunately you have to 'sacrifice' a set of original gauges,mine were toast anyway. There's also a tech tip from another fellow 'bolter Danimal on the New Vintage site. To be fair,that's where I got the idea in the first place.... Thanks again Dan!
| | | | | Joined: Sep 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 48 | I USED THE NEW VINTGAGES IN MY 53 3100, HAD TO GET TRIM RINGS FROM DOC'S KUSTOMS, BE CAREFUL WE HAD TO MACHINE THEM SO THE GAUGES ACTUALLY FIT IN THEM , FOR THE MONEY THE GAUGES ARE WELL WORTH IT,, INSTRUCTIONS ARE EASY ALTHOUGH I REWIRED MY TRUCK WITH A NEW HARNESS FROM REBEL WIRING(ANOTHER GREAT PRODUCT FOR THE MONEY)SO IT WAS PRETTY SIMPLE AND THEY ARE THERE IF YOU HAVE ANY QUESTIONS.. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | SCPOUSN, I didn't want to pay the $$ for the adapters(I'm cheap) BTW You can turn your Caps lock off,there no need to SHOUT about it!  Joe, thats the very same one, Dan did his for the later gauges,so I just 'adapted' ('scuse the pun) the technique to suit the earlier pre 54 ones. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
