| | | Forums66 Topics128,086 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | ok i have a question??? How difficult is it to convert a step bed to a cameo bed.???Chevrolet says that the cameo sides go over the exsisting step side bed sides.and the floor and the front bed panel is all the same. and then al you got to do is work on putting on a cameo tailgate and all hardware . and change the rear bumper brackes to accept a cameo bumper but my real questions is the sides and tailgate can it be done using a ste side bed as they say you???
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Want to try that again with some punctuation? | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | There are numerous "Cameo only" components which are not reproduced. The bed sides, tail lights, and some of the trim and emblems are available. If you can find a donor vehicle for the hard to find parts you may be able to make it happen. The metal bed is essentially the same with holes drilled in the top and sides of the bed to accomodate the Cameo side panels, support brackets, etc. Fred
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Someone on this site directed me to a company that makes complete Cameo conversions. You'll have to search but I think one was Gibbon Fiberglass and and the other was Carolina Conversions? But if you do a search, you'll see that others have done this using such conversion kits. I think the cost was about $2,500. I don't know if either is in business anymore. Didn't work for me because I have a long bed truck. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | |
