5 members (Shade Baby, Otto Skorzeny, DadsFirstPickup, greenie-reddy, Wayne67vert), 112 guests, and 1 robot.
Topics128,147
Posts1,056,798
Members48,454
Hello, I just got a 1964 C10, 230 six, i found the rubber vacuum advance line broken off and I can't seem to find where it goes, the only vacuum line I see is for the PCV valve. Any ideas?
Thanks, Alan
There should be a connection at the base of the carburetor. Some are in the front and some are behind where it may be hard to see.
Riding in the Passing Lane
If it has a Roch. model B carb ther is a 1/8 in. pipe thread hole on the valve cover side that should have a fitting in it. The hose or tube attaches to the fitting.
1972 Chevy c10 Cheyenne Super
Thanks! is that fitting on the same side as the distributer?
Let me try to clarify what George was explaining. The fitting is on the carburetor throat above where it bolts to the intake manifold. It faces the valve cover so it's hard to see. If you have the model B carburetor, I believe the vacuum line was hard lined to the carburetor with a threaded fitting. Since you mentioned HOSE, you may have a hose bib in the same location.
Oh OK thanks
