3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
Apprentice
Apprentice
Finally got to drive the truck parked it and found that it was locked in reverse position. Could not seem to get it out of gear. I pulled the top cover and inspected the fork yokes and shifted everything back and forth. Installed cover/shifter what I thought was in neutral, Upon testing I have 1st/2nd gear it appears, but reverse shows to be a forward gear also! Help!
What am I missing? Is there a step by step process for setting the gears correctly and mounting the top cover plate/shifter?
It would help if you identified your transmission.
Riding in the Passing Lane
Yes if it's a 68 up it's a different ball game.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
Sorry Guys, I will look it up, and let you know
Apprentice
Apprentice
http://chevy.oldcarmanualproject.com/chevyresto/53153.htm
4-speed on right of page
Castings #
GM13 591568 (Top Cover left edge)
J2 2 (Top Cover Bottom right corner)
Any process sheet/info help to get the shifter set back in right way to shift the right way..
Would be much appreciated!!!
Apprentice
Apprentice
Castings #
Apprentice
Apprentice
#680506 - 09/25/10 03:01 PM Re: 4-Speed Locked In Reverse--Help [Re: MichaelR]
MichaelR
Apprentice Registered: 02/17/08
Loc: Minneapolis
Castings #
Apprentice
Apprentice
MichaelR
Loc: Minneapolis
Castings #
ok, we hear you
Redryder pix
My Hotrod
Pull out the gearshift lever. If you are not familiar with it press down on the coller with pliers & turn it about 15-20 degrees counterclockwise. All the openings in the rails should be lined up. If not take big screw driver & line them up. It should be in neatral. Jack up a rear wheel & it should turn. Put the lever back in & try it. If it doesn't work right pull the top off & make sure the forks & reverse lug are going into the grooves. If it still doesn't work put the cover in a vise or clamp it down upside down. Work the rails. They should have a good snap to them. Only one rail at a time can be out of neatral position. If thats ok you have something wrong in the trans.
Apprentice
Apprentice
Thanks Wrench! I will try this weekend
Apprentice
Apprentice
Wrench
Finally got the gear alignment in neutral and the forks line up. Also found the reverse lever was loose and missing a bell or wavy washer
Everything works Now!
I wil try post post pictures someday for the guys like me not heavy on transmissions.
