4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#680485 09/25/2010 5:22 PM
I am looking to change out the rear end in my 65, I would like to go with something with Disc brakes and am looking for some advice on what year and rear end to use to make it as easy and painless as possible. I plan on adding drop spindles with disc brakes to the front and will be getting the whole new master cylinder and booster, so though would do the rear end at same time. Will also be going with a 700R4 tranny.
Randy Tupa #680500 09/25/2010 7:23 PM
Since you're going to use an overdrive trans, I would suggest sticking with the stock rearend and adding an aftermarket disk brake conversion. That would be the easiest way to go. There are kits available, and if you want to convert to 5 lug, that's easy, too. Just swap to '71-'87 axle shafts, which are a bolt in after being shortened to the earlier axle length and regrooved for the C lock.
Bill Burmeister
LONGBOX55 #680652 09/26/2010 2:54 PM
The reason for the rear end change is due to chattering that I have during sharp turns at low speeds. I have tried an additive in the rear end, but the chattering is still there.
Randy Tupa #680930 09/27/2010 5:11 AM
sounds like you have a detroit locker in there.
