| | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | ordered a new push rod to replace the one bent one that resulted from a timing gear failure. to be kind, the new one is less than impressive. so i have spent a few hours attempting to straighten the old one. it now rolls as straight as all the other push rods but i am wondering if i am just fooling myself into believing that it is just fine or if i should just put the new one in and run with it?
the old rod was not bent significantly but it was obvious that it took a hit.
thoughts?
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I have straightened them with no problems. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It was common practice years ago to straighten pushrods. My Dad was telling me about pounding them straight alongside the road when he would over rev his 348 powered '59 Impala. | | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | thanks for the feedback. was also considering polishing up the ends prior to re-assembly. good idea or should i just clean them up and put em back in? | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | If they are rusty, polishing with a buffing wheel wouldn't hurt, but don't use anything abrasive. | | |
