2 members (Peggy M, Ponchogl),
52
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67976 10/30/2006 4:20 AM | Joined: Sep 2006 Posts: 43 Apprentice | | Apprentice Joined: Sep 2006 Posts: 43 | Hi Guys
i have recently rebuilt my rochseter B carb and now i am trying to set the proper timing on my 216. i am setting my timing as per the manula of 5 degrees before TDC. One i crank the engine to 5 degrees before TDC i set the distributor right before firing the first cylinder. I hope that is correct. for my next problem after i put my distributor in all the way and i tighten it up and i try t start the car the distributor jumps 180 degrees.
Thanks CHaimv | | |
#67977 10/30/2006 4:49 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | It may not have been all the way into the oil pump when you installed it. You can't time it when it isn't installed. | | |
#67978 10/30/2006 5:20 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | When you install the dist, look down the hole and use your 15" screwdriver to rotate the oil pump drive . Allow for the dist to rotate as it meshes with the drive gear before it slides into the oil pump tang. | | |
#67979 10/30/2006 5:36 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | before you put dist. in you want engine at 0 degrees, or top dead center. as stated above you can't time it without dist in. and if dist. jumps your not getting it in all the way..using screwdriver, turn the pump where you want it, then when you put dist. in, start it a with the tang a bit to the left, so when it hits the gear it will turn a bit,line up and drop all the way in.. | | |
