1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Does anyone make a new rubber floor mat for the cargo area of a 64-66 suburban, I am going to use it for a pickup under the seat after using dyna mat so I want the floor to look like it came with the mat originally....Thanks for any help.
Ps I did a search and got so many threads that I could not sort thru them. Kieth
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
k10 Offline
LMC would probably be the one to check if anything is available. If that doesn't pan out, you could buy a pickup bedmatand it could be a good fit if the inner fenders are similar to the pickup's. Again, LMC would be one of the vendors to check.
thanks, I did look there and they do have something which may work. Thanks for the suggestion. Kieth
66 GMC SWB
65 Chevy LWB
65 GMC SWB
918-446-2245
I measured my 66 carryall and it is 67" wide and 93 " long -so say 6 ft.x8 ft =48 sq. ft. and i believe the price is $6.00 sq. ft. so price for mycarryall should be $288.00 plus shipping ? does anybody know if this right OR has anybody ordered and got some yet ? thanks mike
Currently cruising
in the
Passing Lane
k10 Offline
http://www.stkusa.com/lineabedmat.cfm
Something like this should only run about 60 bucks. $288 is WAY too much money for a simple piece of rubber. Just pull up generic bed mat on Google and start from there. You can measure your inner fenders and their relative positions to headboard and tailgate and call the mfg and see what's closest. I do know that the 73-87 metal beds are used by the 60-66 guys as an alternative to the wood floor. And "they say" that the fir perfectly. so that may be a place to start.
hi guys what im talking about is not a pick-up bed mat /this is the floor covering for the rear of a carryall !its called "battleship linoleum"you cannot just throw this in the back of the carryall ,the body has to be lifted up and the old floor unbolted and separated from the body then installed !
Currently cruising
in the
Passing Lane
k10 Offline
Alright then Wahl. You didn't start the topic. Keith did. He asked for a rubber mat. You made no mention of lino until just now. If you want battleship lino, please refer to another current thread on the topic. It is on the first 2 pages and has quite a long list of responses. Search is your friend.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=641321#Post641321
Sir Searchalot
Sir Searchalot
Hey K10: Wahl was in that very thread on 8/8 and knows the whole story already. He could have searched his own posts and found it. I'm even in that thread and I mention Wahl in my post, what a small world.
