0 members (),
330
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | Does anyone make a new rubber floor mat for the cargo area of a 64-66 suburban, I am going to use it for a pickup under the seat after using dyna mat so I want the floor to look like it came with the mat originally....Thanks for any help.
Ps I did a search and got so many threads that I could not sort thru them. Kieth
66 GMC SWB 65 Chevy LWB 65 GMC SWB
918-446-2245
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | LMC would probably be the one to check if anything is available. If that doesn't pan out, you could buy a pickup bedmatand it could be a good fit if the inner fenders are similar to the pickup's. Again, LMC would be one of the vendors to check. | | | | | Joined: Aug 2010 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 96 | thanks, I did look there and they do have something which may work. Thanks for the suggestion. Kieth
918-446-2245
| | | | | Joined: Mar 2000 Posts: 137 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 137 | I measured my 66 carryall and it is 67" wide and 93 " long -so say 6 ft.x8 ft =48 sq. ft. and i believe the price is $6.00 sq. ft. so price for mycarryall should be $288.00 plus shipping ? does anybody know if this right OR has anybody ordered and got some yet ? thanks mike | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | http://www.stkusa.com/lineabedmat.cfmSomething like this should only run about 60 bucks. $288 is WAY too much money for a simple piece of rubber. Just pull up generic bed mat on Google and start from there. You can measure your inner fenders and their relative positions to headboard and tailgate and call the mfg and see what's closest. I do know that the 73-87 metal beds are used by the 60-66 guys as an alternative to the wood floor. And "they say" that the fir perfectly. so that may be a place to start. | | | | | Joined: Mar 2000 Posts: 137 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 137 | hi guys what im talking about is not a pick-up bed mat /this is the floor covering for the rear of a carryall !its called "battleship linoleum"you cannot just throw this in the back of the carryall ,the body has to be lifted up and the old floor unbolted and separated from the body then installed ! | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Alright then Wahl. You didn't start the topic. Keith did. He asked for a rubber mat. You made no mention of lino until just now. If you want battleship lino, please refer to another current thread on the topic. It is on the first 2 pages and has quite a long list of responses. Search is your friend. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=641321#Post641321 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Hey K10: Wahl was in that very thread on 8/8 and knows the whole story already. He could have searched his own posts and found it. I'm even in that thread and I mention Wahl in my post, what a small world.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
