10 members (Samantha, Bill Hanlon, 55shaker, 1955 1 Series, cmayna, Otto Skorzeny, Stelonlevo, JW51, treegrower, 1 invisible),
133
Mod | | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 24 New Guy | | New Guy Joined: Jun 2006 Posts: 24 | I'm re-assembling painted chassis and suspension parts. Must the through holes be cleaned of paint? Such as where a tierod connects to a knuckle, or where metal pieces mate. Just want to hear what I'm thinking.
1957 3805 Panel It's not how you fall down, but how you get back up.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I'm thinking it will depend on the part. You won't want much contamination in greased fittings where parts are intended to move. You also will not want to mar the mating surfaces of machined parts. I would clean them out with lacquer thinner, and avoid sanding if at all possible.
EDIT: for future reference put a thin coating of wheel bearing grease on the machined surfaces prior to paint. After painting they can be wiped out with a shop rag taking the grease, paint and all.
