2 members (mo2cyl, Rusty Heaps),
59
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I just bought a 55-59 3sp overdrive. I plan to put it behind the 235 in my 31 pickup. I need to get up to speed on this tranny. What are the gear ratios? The rearend has 3:42 gears. It has a small lever thatI assume uses a push/pull cable to operate the overdrive. What is the electic solenoid for and how is it wired up. Thanks | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | There is lots of information written in this forum about OD's. My recommendation would be to pick up a 55-59 shop manual which has all the information needed, wiring diagram, trouble shooting, etc. GM used OD's from 55-69 in cars and trucks. In addition to the solenoid you should have a govenor (mounted on the rear housing) pull cable, kick down switch, relay, and wire loom. Fred
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Although an OD came from the factory with a kick-down switch and a relay, you can hook one up with just the cable and a toggle switch.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | This website has l-inks to a bunch of OD documents. I just put one in my burb and this helped a bunch.
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | The front part of the transmission is just like a normal Chev 3 speed. The back part is a planetary unit with .70 overdrive built by Borg Warner. This is a pretty good over view of the OD http://www.hydratech.com/pctc/Public_Documents/bwwiring.pdf I would not put an OD in front of 3.42 gears. They are a lot more driveable with 3.90 or 4.11. I have OD in all my Y-blocks.. have for almost 50 years. I have an OD that I am going to put in in a GMC, but it will be with 3.90. I bid on an OD on eBay last week. You may be the one that outbid me at the last 5 seconds, but there will be more. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Is the OAL of the standard 3 speed and the OD unit the same so it can be put in a truck with the torque tube? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As far as I know, there was no OD trans built that will accept the torque tube set up. They require the slip joint of the open driveshaft. I swapped to a '55 first rear end. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Thanks Cletis, that is what I thought. This OD question comes up quite often and I think a lot of folks with pre 55-1 think all they have to do is swap out the tranny. Obviously a lot more to it. But you know how so many people ask a question but don't say what truck it pertains to and get the wrong impression. | | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | Thanks to everybody who took time to reply. I paid $75 for the tranny at a swap meet. Straight 3spd transmissions were going for about $50. It's always fun learning new things. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You made a terrific deal @ $75 IMO. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Kenneth's advice on using 3.90 or 4.11 gears is right on. I'm using the 3.90s and that makes a 2.73 final drive. It's slows the 248 down on hills at highway speed. I don't think it could handle any higher ratio. | | |
