1 members (RLB),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I am looking for a 3 series rear end to put in the 66 Burb. I found one ( have not looked at it yet), but the man tells me that its a 12 bolt truck, 6 lug, with leaf springs. I don't care about the housing, but will the guts in this still fit inside of mine if it is a 65 -70, even though mine is coil springs?
Thank you | | | | | Joined: Jun 2007 Posts: 30 New Guy | | New Guy Joined: Jun 2007 Posts: 30 | Change the mounts on the new rear and use the whole thing. Mounts will have to be cut off the old and welded on the new one to match your suspension style. 1950 3100 3 windo 1951 gmc 102 1958 chevy 3200 1959 gmc 102 1963 c20 1959 buick lesabre 1961 buick lesabre
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I looked at this rear end today, and now I am confused. I am looking for axles and guts to put into my existing 66 rear end. The one I looked at today was 6 lug, leaf spring perch's, the axle spline was the same, but the axles were about 3/4" longer than mine. They casting date looked like a 6, but it was located on the front of the housing, not where mine is. The Brake Drums were finned and larger than mine. The rear cover seemed teh same as a 12 bolt
My question is, what would have this come out of? I thought the 6 lug went out in 70-71?
Would the center carrier be the same in this as in mine?
Thank you for your help. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | 73' up 4x4 rearend! they were wider so the "6" is probably 76'! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Agreed, 4x4 rearend. Side note, '71 and '72 are also wider than the '70 and earlier.
Bill Burmeister | | |
