Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (ShopRag, farmallb, jasrking, TUTS 59), 34 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#678903 09/19/2010 5:05 PM
I just bought a 55-59 3sp overdrive. I plan to put it behind the 235 in my 31 pickup. I need to get up to speed on this tranny. What are the gear ratios? The rearend has 3:42 gears. It has a small lever thatI assume uses a push/pull cable to operate the overdrive. What is the electic solenoid for and how is it wired up. Thanks
Fortynine5 #678917 09/19/2010 5:23 PM
There is lots of information written in this forum about OD's.
My recommendation would be to pick up a 55-59 shop manual which has all the information needed, wiring diagram, trouble shooting, etc. GM used OD's from 55-69 in cars and trucks.
In addition to the solenoid you should have a govenor (mounted on the rear housing) pull cable, kick down switch, relay, and wire loom.
Fred
rfs56trk #678942 09/19/2010 7:29 PM
Although an OD came from the factory with a kick-down switch and a relay, you can hook one up with just the cable and a toggle switch.
My Blog
Pre '68 Dave #678946 09/19/2010 8:00 PM
This website has l-inks to a bunch of OD documents. I just put one in my burb and this helped a bunch.
Pre '68 Dave #678950 09/19/2010 8:07 PM
The front part of the transmission is just like a normal Chev 3 speed. The back part is a planetary unit with .70 overdrive built by Borg Warner. This is a pretty good over view of the OD http://www.hydratech.com/pctc/Public_Documents/bwwiring.pdf I would not put an OD in front of 3.42 gears. They are a lot more driveable with 3.90 or 4.11. I have OD in all my Y-blocks.. have for almost 50 years. I have an OD that I am going to put in in a GMC, but it will be with 3.90. I bid on an OD on eBay last week. You may be the one that outbid me at the last 5 seconds, but there will be more.
crenwelge #679188 09/20/2010 5:30 PM
Is the OAL of the standard 3 speed and the OD unit the same so it can be put in a truck with the torque tube?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #679219 09/20/2010 7:29 PM
As far as I know, there was no OD trans built that will accept the torque tube set up. They require the slip joint of the open driveshaft. I swapped to a '55 first rear end.
Cletis #679252 09/20/2010 9:58 PM
Thanks Cletis, that is what I thought. This OD question comes up quite often and I think a lot of folks with pre 55-1 think all they have to do is swap out the tranny. Obviously a lot more to it. But you know how so many people ask a question but don't say what truck it pertains to and get the wrong impression.
Dave
Cletis #679253 09/20/2010 10:00 PM
Thanks to everybody who took time to reply. I paid $75 for the tranny at a swap meet. Straight 3spd transmissions were going for about $50. It's always fun learning new things.
Fortynine5 #679260 09/20/2010 10:18 PM
You made a terrific deal @ $75 IMO.
Dave
53moneypit #679266 09/20/2010 10:28 PM
Kenneth's advice on using 3.90 or 4.11 gears is right on. I'm using the 3.90s and that makes a 2.73 final drive. It's slows the 248 down on hills at highway speed. I don't think it could handle any higher ratio.
