5 members (WICruiser, wilbur53, baldeagle, panel fan, GMCJammer51), 141 guests, and 3 robots.
Topics128,038
Posts1,055,471
Members48,424
#678710 09/18/2010 11:37 PM
Hello I have a 1953 chevy 3100 and I'm upgrading the tie rods to modern ones can anyone tell me what direction they will go in from.For example will they go from the bottom pointing up with the castle nut on top or will they be pointing down with the castle nut on the bottom ?Thanks for the help
sal moreno #678753 09/19/2010 2:33 AM
From the top nut down.
ttodd #678907 09/19/2010 5:10 PM
Okay thats kinda what I was thinking too but wasnt sure.How are those working out for you?
sal moreno #678949 09/19/2010 8:05 PM
There is only one way they will work. the male piece fits the the taper in the bottom.
sal moreno #679016 09/20/2010 1:18 AM
If your using a dropped axle they will need to go in from the bottom up with the nut on top. The upgrade modern tie rods that the chevy parts vendors sell are not tapered. You pop out the old ball and you end up with a straight hole.
Chato #679282 09/20/2010 11:02 PM
i second that. on my 3 inch dropped axle, i went with modern ford tapered tie rod ends, and they go in from the bottom with the castle nut on top.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
