2 members (Stovebolt48, 1 invisible),
131
Mod | | | Forums66 Topics128,211 Posts1,057,473 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | I've seen one of these before it bolts to the drivers side of the engine at the oil distribution.... I forget what its called. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is called an In-liner filter, or something like that. It bolts on in place of the oil distributor cover. Instead of returning filtered oil to the pan, the filtered oil goes to the rocker arm supply. | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Hey, truckernix:
This in-liner filter sounds like a good idea. The Blue Funk has the type you mentioned, where the filtered oil is returned to the pan.
I wonder if there is any such animal like this in-liner filter currently available? | | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | That is called an In-liner filter, or something like that. It bolts on in place of the oil distributor cover. Instead of returning filtered oil to the pan, the filtered oil goes to the rocker arm supply. For a 216 splash-oiler, quite a rare part. I've seen one in the past 15 years but I don't get around much.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think there were far fewer of the in-liners than the other type. They are a little neater with no external lines. | | | | | Joined: Jan 2008 Posts: 21 Apprentice | | Apprentice Joined: Jan 2008 Posts: 21 | | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | Thanks for the pictures. I've never seen one of that style.You did a great paint job also. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That looks really nice. It will look even better in your engine bay! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | A friend has one that he highly polished so it looked like a chrome finish. It's a cool looking filter that generates a lot of conversation. Nice job.
Drew
