| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 33 | Hey All, Would like to replace the rims on my 1953 3/4 ton, like to get rid of the split rims setup that I have now, but would like to keep that stock look. Help Thanks Cardo
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Nice looking 3/4-ton!! I still have the original 2-piece rims on my 50 but many people have found Dodge or Ford 8-lug 1-piece rims that fit. Almost any 3/4-ton truck wheel from the 40's to 90's will have the same 8 x 6.5 bolt hole pattern but many are too wide, especially at the front. The wheel must have a shallow inset or the inside of the rim will rub the tie rod ends. Some guys have used trailer wheels from RedNeck and other supply stores. Try a search of these forums as this has been discussed many times before. And good luck with your truck!
Professional Novice
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I have 16" rims form a ford van on my 54 3600. They fit quite well. I only have about an 1/8 of an inch clearance on the front tie rod, but no rubbing. I need to get some hubcap clips in order for the hubcaps to fit the wheels, but they still look good. | | | | | Joined: Jun 2007 Posts: 30 New Guy | | New Guy Joined: Jun 2007 Posts: 30 | I like the vintage look too and know what you're asking. Try finding a set or 17.5, or if you are lucky 19.5 Kelsey Hayes GM wheels from a late 50's-60's 3/4 ton truck. Gmc's are more likely to have them. They will allow you to keep your original hubcaps,and fit your stock suspension. Tires for these wheels can be a bit pricey, and there arent too many choices but they look like they belong on your truck. They are skinny and tall. 1950 3100 3 windo 1951 gmc 102 1958 chevy 3200 1959 gmc 102 1963 c20 1959 buick lesabre 1961 buick lesabre
