6 members (MickeyP, Hotrod Lincoln, Nick in Manitou, KingG, 2 invisible), 108 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#676111 09/07/2010 3:39 AM
Hey All, Would like to replace the rims on my 1953 3/4 ton, like to get rid of the split rims setup that I have now, but would like to keep that stock look. Help
Thanks Cardo
Nice looking 3/4-ton!!
I still have the original 2-piece rims on my 50 but many people have found Dodge or Ford 8-lug 1-piece rims that fit. Almost any 3/4-ton truck wheel from the 40's to 90's will have the same 8 x 6.5 bolt hole pattern but many are too wide, especially at the front. The wheel must have a shallow inset or the inside of the rim will rub the tie rod ends. Some guys have used trailer wheels from RedNeck and other supply stores.
Try a search of these forums as this has been discussed many times before. And good luck with your truck!
Professional Novice
Frank50 #677246 09/12/2010 4:09 AM
I have 16" rims form a ford van on my 54 3600. They fit quite well. I only have about an 1/8 of an inch clearance on the front tie rod, but no rubbing. I need to get some hubcap clips in order for the hubcaps to fit the wheels, but they still look good.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #678623 09/18/2010 4:36 PM
I like the vintage look too and know what you're asking. Try finding a set or 17.5, or if you are lucky 19.5 Kelsey Hayes GM wheels from a late 50's-60's 3/4 ton truck. Gmc's are more likely to have them. They will allow you to keep your original hubcaps,and fit your stock suspension. Tires for these wheels can be a bit pricey, and there arent too many choices but they look like they belong on your truck. They are skinny and tall.
1950 3100 3 windo
1951 gmc 102
1958 chevy 3200
1959 gmc 102
1963 c20
1959 buick lesabre
1961 buick lesabre
