8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert),
94
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | After converting my ’41 to 12 volts my 6V horn still works but sounds somewhat anemic. I’m looking for suggestions for a 12V horn that looks close to the stock 6V unit and can be mounted on the intake manifold. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think your horn needs an adjustment. My six volt horn is really loud on 12 volts. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ditto, a 6v horn on 12v should be a lot louder.
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | try filing the vibrator points...... | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I'm also interested to learn of an aftermarket 12v horn that looks and sounds like the original horn. So, going back to the original question, does anyone have a recommendation for a source for original looking horns? I have no problem finding original sounding horns, but they don't look much like the broken original that I replaced with a cheap aftermarket. Bill | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if the new one was cheap it might be worth a try to take it apart and put the guts in the case of the old one - if it doesn't work you're not out much - find a working original
Bill | | | | | Joined: Feb 2000 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 38 | Good idea, putting new guts in old case. I'll try that sometime. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | I bought a $15 horn at O'Reilly. Works great, sounds great. It doesn't look that out of place, either. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Put an ad in Truck Parts Wanted. You can get used horns that work for a reasonable price. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You won't find a 12V like that on a Chevrolet. | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | Kip, For what it's worth, when I had my '46 (with a '41 cab, so whatever) rewired the guy that did the work suggested I install mid 70's Ford (ugh!) twin horns. They are LOUD and sound right. They look much like the ones in the link from TxLaTx above but I put them behind the grill instead of in the engine compartment. Besides, I've got a 350/350 and IFS/IRS so authenticity is no longer an issue. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks guys.
I have adjusted mine and it is a little better. It's not so much the loudness but the sound it makes. It sounds more like ahhhhhhhhhhhh than toot. I tried the horn with my old 6V battery and the sound is about the same
The truck is mostly stock and I would like to keep the horn where it is bolted to the manifold.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Someone had put a "meep-meep" horn on my burb. I found a pair of 6V Olds horns at a swap meet. They sound off nicely on 12V. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I pulled a pair off a mid-70's/80's chevy truck at the salvage yard, mounted them under the "hood latch pan", and they sound like caddy horns. Don't forget to get about 8-10 feet of the wire with them. | | |
