I doubt if you will find any "adapters" that allow you to bolt the 292 right in. My understanding is the 292 motor mounts are staggered? Camaros 6's the mounts were straight across like a V8. I would strongly suggest you take some measurements to determine the exact location for the engine. Most likely you'll have to custom build the motor mounts. Hang in there, someone with more knowledge on the subject will come along and add more information I'm sure. Another issue maybe the oil pan clearance on the crossmember.
