2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
Apprentice
Apprentice
I have body work done and am thinking of using a newer 1 ton chevy frame. Brakes, steering, wheel/tire issues... Just think putting body on 1989 chassis makes sense. Anyone done this?
The '88 to '98 frames have kickups front and rear and the front is much wider than your '47.
I haven't done it, and I'm not saying it can't be done, but there would be easier frames to put your body on.
Apprentice
Apprentice
Any ideas on what would work best? Anyone? Anyone? I don't want to get too old and lose the benefits of modern suspension, steering...any of the hot rod material work? Mustang II? Chevelle?? Monte Carlo?
What would work best?
Well the original frame is a great choice, and in my case I think it's the best choice.
I have new springs, power steering, as well as disc brakes front and rear. And it all looks pretty much like it belongs, and the frame fits wonderfully under the body.
I've seen a number of AD trucks on non original frames, and I've yet to see one that looked right.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
How do you plan to use the truck when its finished? Looking at frames designed for your purpose would be the place to start. Then narrow the field based on track width and wheel base.
You may not find anything that really makes sense, or you may find a perfect match.
If you want modern suspension you either have to build suspension mounts or body mounts. I've got projects underway doing it both ways and have yet to be convinced one or the other is always the right answer.
